View Full Version : LT1 Based Engine Tech
- Oliver 4 Bolt splayed caps problem...
- Not enough Air in the Air Chamber with CAI ?
- what is your solid roller grind and how streetable is it?
- Shift kit questions
- What MSD Coil Replaces The OEM Coil?
- I'm doing my intake gaskets and I need a little help
- Questions about 2 large elec. plugs near pcm
- weird vibration
- Info for those who claim their Flowmaster "Drones"
- SLP linelock question
- people with bmr lca's
- Header Gaskets
- Rebuild Lt1 with more power
- What is MALF 16: Lo-Res Fail
- Couldn't make ET streets stick today
- Anyone have before/after bigger TB?
- Is it possible to pull the heads without draining the block?
- Installed torque converter today, my thoughts and a ??
- Mystery sensor? Any clue?
- Vibration I can no longer stand
- Cheapest Adapter Kit for 93-95 LT1 for SLP Loudmouth
- first mods on 94 z m6 48,xxx miles????
- stock or not?
- is this normal?
- pics of polished slp cai installed?
- Torque Limit on LT1
- Double Brakeout results in Runner-Up at 2003 Spring Break Shoot-Out
- Opinions on Dynatech headers....anyone have them?
- U-Joints
- 95 tranny in a '94. Any wiring issues?
- Alternative to LT4 Hot Cam Kit
- Could "very loose" rocker arms cause loss of of horsepower?
- COAN stall question
- Removing Intake and Fuel Lines
- Rearview Mirror
- th350 part question...was posted before, cant find it now
- Opti conversion
- New shifter install?
- Fan Mod for '94?
- Rough idle, unplugged TPS and its a performer
- if i buy a K&N air filter
- HELP, LOUD Knock coming from Exhuast underneath COLUM
- It Runs !!!
- 1.6 rr's
- Mpg
- Which Plug to use with Hot Cam?
- Need help finding turn signal relay on 97Z
- Question about installing head/intake gaskets...
- Pull engine with condenser & compressor in egine bay?
- brake locked up?
- how big is the difference in the vigalante 2800 and the slp 2800?
- Need to know the bolt pattern and tq. # for intake and head bolts ASAP!
- went to the track sat
- electric fans
- ABS plug/wire relocation with long tube headers
- cc305 and cc503 ?
- Can I use Crane 10380-1 kit with stock rockers and cc306, and do 1.6 rockers later?
- what should I set my shift points too with my mods?
- 02 sensor install q
- MSD6AL have internal fuse?
- why is there no aftermarket for the 10 bolt?
- trans problems
- Need help about headers
- Emergency - Rear Brakes
- Anyone have pics of the ls1 brake upgrade?
- LS1 TQ on LT1
- Throttlebody boring
- Need help with valve spring install
- 3.73 or 4.10
- LT4 intake part #?
- Help !!! cloyes install
- a4 wont shift out of park
- coil; get from dealer or is autozone ok
- t-56 not wanting to go into gear
- Is my Opti causing this !!!
- AS&M throttle body
- easiest shorty headers to install
- Hard to turn wheels out of reverse
- pro 5.0 -1'' or short stick?
- Hooker LTs... should I still do true duals or just a cat-back?
- Drive shaft BUY or have Made
- Are the spark plugs different from 1995 to 1997?
- LT1 to LS1 injectors
- H E L P 94 scan tool?..have SES LIGHT
- new motor, no oil pessure!!
- is there a website that has different exhaust sounds?
- which dynomax muffler is best for me?
- Summit LT1 Rebuild Kit??
- 3/8" studs w/ solid roller?
- Could This Possibly Be A Bad Coil?
- again offroad pipe?????
- SES light
- any seen these subframes
- changing clutch fluid
- I'm sick of searching catback?
- Help finding header
- Holley 52 tb or BBk????
- Hooker LT concerns...
- Removal of Crank Hub
- its always somthing
- What do you think about AS&M headers
- Gears on a CC306??
- looking for a good 383 hyd roller cam
- what seals to replace when doing cam swap??
- SLP Dual/Dual
- shoebox; opti test ?
- Broken Brake ! Take a look
- I took some pics, are my headers bending?
- Cheapest place to get GM 3.42's and install kit??
- Just sold my Eclipse GS-T
- Could you have a CC305 ground on a 112??
- Where is the cheapest place to get nitto's
- Turn signal won't blink
- LT1 crank keyway question????
- cluster replacement questions
- HELP! Air Conditioner Drain Clogged
- part number
- Dynomax catback installed today
- Coolant Temp. Sensor
- Time for summer upgrades
- plug wires
- shoebox, you rule.
- Redline or Mobil 1?????
- Quick Question about rockers...............
- stall question
- Descreened MAF today got some ?'s
- help! easiest way to put door panel back on!
- Sunoco94 experiences good / bad?
- Anyone with Long Tubes on a Convertible??
- Starter Help
- Which year LT1 will this BBK throttle body fit? Pics inside....
- please help! stuck on tranny removal
- Anyone else with an m6 pop out of 3rd gear?
- Any guesses?
- Is it worth to buy used gears?
- LS1 trans mount for my 94Z A4 doesn't fit. Different part # for auto vs. manual?
- is there a csi elect water pump for a 96 if not should i go meziere
- LT1 block; different from a regular 350 block?
- v6 lt1 swap question.. please help
- lt1 swap question PLEASE help!!!
- 4L60E suopse to go into OD@WOT
- 02 Sims and no Cats. just got SES light and stumbling???
- Here's some pic's
- NASTY sound...like marbles in the intake, TAKE A LISTEN, Help please!
- car wont start on first crank after it sits
- Header Question...NEED HELP QUICK!!!
- Fel-Pro Header gasket Q???
- Car Totaled
- mac installation problems
- Best LT hedder ?
- gear input
- Vss wire ?'s A4-M6
- U-Joint size for a 95'
- Removing dash panel
- SES Light...
- Is this a good deal on z28 need advice
- 2otl
- No Tach or Speedometer
- I need help and fast!!!!!!!! Please anyone!!
- Whats wrong with my long term fuel?
- which mobil 1 formula
- Dyno Numbers on my LT1...
- Thinking of buy a vette
- Where can i find it
- Oil presure '94 Z28?
- cheapest cats that fit for true duals/longtubes
- Problem With Z
- Taillights Melted!!?
- banks 1 and 2 lean condition
- car starts but not on the frist try
- Et Street Problem!!!!!!!!!!
- Those of you with stutters, shakes, and hesitation under light throttle...
- Need Help! Car Wont Start!
- 1997 Camaro SS RK Sport edition?
- jet injectors cleaned?
- Ball Joint Question
- Where to get neutral balanced flexplate
- LT1 Motor Mounts
- How do i know if my SLP 2OTL has a silencer in it????
- car acting up, need advise
- Is this gauge swap possible?
- Advice on 383
- what intakes?
- need help with rebuild stuff
- Alright I want some headers..
- Lock cylinder R&R
- What brand flexplate w/ 383 and th350?
- Edelbrock headers? and and air foil?
- How much should I ask for my car?
- Where to get headers coated in Dallas
- removing front swaybar.. pros/cons?
- Difference between 306 and 305 tuning?
- AS&M shorties, what kind of gains?
- t-56 owners
- o
- offroad pipe
- 13.0's with stock manifolds....anyone?
- 700R4 to T56
- GM C5 front brake brackets?
- What kinda of HP numbers with "insert cam here" and 100shot of N20??
- next part
- spintech exhaust
- is slp cai gonna help with mpg?
- question about takin gcat out and sound with flowmaster
- pro 5.0 shifter with hurst nob?????
- suspension and computer tuning
- help-replaced h2o pump,no fire @ coil?
- will i smog with these mods??
- HAHA Odometer Idea, read
- jenny craig?
- HELP: Rough idle and VERY bad gas mileage
- Got a cracked rim...
- Please Help Me!
- How did you seal you leaky y pipe???
- Can JB Weld seal a hole the size of a pinhead on my A/C line???
- what spark plugs?
- LT1/4 balancer hub
- Grotyohann y-pipe??????
- Wiring switch for fans on a 93?
- power lock proublem
- ?passenger plug wires?
- Looks like I'm pulling the motor...
- 4L60E to a 700R4
- Which Balancer Should I Get?
- Would I see a gain from bigger TB
- sensor in the driver head???
- 4L60E are all years interchangable????
- Knock Module & Coolant Drain Plug Removal
- Dipstick and 4 bolt splayed cap (oliver) question
- spark wires configuration on opti?
- little help please!!
- 160 deg t-stat?
- vapor canister
- cam only dynos
- What to do first?
- Low coolant light. New radiator has no spot for it????
- Loudmouth or Borla????
- what does a major exhaust manifold leak on both sides cause?
- tires for my formula
- Optispark
- What to do with this line with vented opti swap
- Convert engine from MAF to SPEED DENSITY
- Will these wheels fit?
- Messed up Threads on Exhaust Bolt
- borla problems
- Sfc
- First Time doing Window Motor Question
- exhaust hangers
- sounds like there is a cricket underneath my hood
- A4 lost 1st &4th
