Can JB Weld seal a hole the size of a pinhead on my A/C line???
I accidently made a very small hole in the A/C line. It lost all the pressure, can I put JB weld to seal the hole?
my stepfather did the same thing to my mother 95 olds cutlass SL, the JB weld lasted about two days and they were out the money for the recharge. They ended up buying the part to replace. I guess it mostly matters wheither it is on the high pressure or low pressure side, hers happened to be on the high side. Good luck!
Dammit I don't wanna replace that... What about RTV, then JB Weld, then a piece of rubber hosing with a clamp around it real tight? Would that hold the pressure??? I know this stupid little hole is not going to make me replace the whole thing.
>Stop being cheap and fix it right !
All I can say is if you nickle and dime this it will get more expensive later down the road .
examples :
1) you temp fix the hose , but it continues to leak ... you have to continue to refill the R134 and oil , and not to mention that you will have to clean the mess (if any) .
2) you refuse to use the A/C and let it "ride" for a while without any refriderant and the A/C compressor dies from no lubrication ( big $$$) while you sweat like a pig in Cali sun .
3) you remove the A/C and get a 1LE A/C delete bracket ... (big $$$) .
all I can say is bite the bullet , and buy the correct hose (AutoZone , Advanced Auto , www.gmpartsdirect.com , GM dealer)
examples :
It's been like that for a few months now... I don't drive it that much. So now my A/C compressor could be bad... that's friggin ridiculous, and i'm not cheap but you can't blame me for trying to find a cheap way to fix it. If it really calls for it I will replace the part.
10-31-2016 11:09 AM
squarehead
11-21-2014 08:02 PM
