Which Plug to use with Hot Cam?
Old Apr 6, 2003 | 05:41 PM
Dale 94 TA GT's Avatar
Just want to know what the best plug to use with the hot cam, ever since I did the cam swap I have had a high rpm miss right before the car shifts from 1-2. I replaced the coil and the plug wires are Taylors but they are a few years old. I put new AC platinum tips in but the problem if anything got worse. I don't think I have an opti problem because the car runs fine everywhere except right before the trans shifts. What wires do you recommend also. Thanks
Old Apr 6, 2003 | 10:39 PM
formula383's Avatar
I am running Autolite 104's and the car runs fine with them. As far as the wires go I really like the Taylor OVC wires.
Old Apr 6, 2003 | 10:51 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I am using Taylor OVC wires and NGK TR55 plugs. No problems with the hotcam set up or anything you mentioned.
Chris
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
Smokn '94 Z
Jul 28, 2002 02:38 AM
