Question about installing head/intake gaskets...
Old Apr 6, 2003 | 05:37 PM
94 CAMRO Z28's Avatar
Cool Question about installing head/intake gaskets...
I believe they are suppose to be installed dry but i just wanted to make sure. Last time I had a very thin coating of copper rtv on the intakes but was told not to after it was to late. So should the head/intake gaskets be installed dry or with rtv? Thanks
Aaron
Old Apr 6, 2003 | 05:39 PM
Rodrigues's Avatar
My head gasket was dry but I used RTV on the front and back of the intake manifold (required actually)
Old Apr 6, 2003 | 05:41 PM
MadMav's Avatar
Dry for the head part of the intake gasket.
Mav
Old Apr 6, 2003 | 05:44 PM
94F1Z28's Avatar
Well first make sure all the mating surfaces are clean and dry and then install the head gaskets dry.Install the intake gaskets dry but use some rtv sealant on the front on back of the intake and run a small bead of sealant under and over the ends of the intake gaskets where they meet the bead of sealant that is running across the front and back.
Old Apr 6, 2003 | 06:06 PM
ltlhomer's Avatar
What they said is exactly what we did so sounds good to me.
Old Apr 6, 2003 | 06:12 PM
Ok thanks again guys. Sounds like what I intended to do but I just wanted to make sure.
Aaron
Old Apr 6, 2003 | 07:01 PM
ltlhomer's Avatar
Always better to be safe and double check :-).
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
