is there a csi elect water pump for a 96 if not should i go meziere
Old Apr 5, 2003 | 06:03 PM
red96z's Avatar
the meziere pump is just to expensive and i want to do an electric water pump
Old Apr 5, 2003 | 06:23 PM
OneFlyn95z28's Avatar
the CSI works great from 92-97. You do need a 1LE bellows to use it on a F-body though
Old Apr 5, 2003 | 10:17 PM
Lunarson's Avatar
If you can find/make something to plug the hole on the bellows, that will work too. I just traced the shape of the hole on a piece of wood, cut it out, put black silicone around it, stuck it in and clamped it down. I covered the outside of the woodplug with silicone to further seal it and take away that ghetto look. I have also seen billet aluminum plugs in RK Sport but they were I think about 50 bucks, you may find them for less somewhere else.
Old Apr 5, 2003 | 10:18 PM
Lets just say i would rather be safe then sorry If or when that hole leaks you car runns lean. I push my car to hard to take the chance
Old Apr 5, 2003 | 10:24 PM
red96z's Avatar
does anyone have the part number for the csi unit that will fit my 96 i already cut the bellows ***** off.
Old Apr 5, 2003 | 10:28 PM
901-LT1
Old Apr 5, 2003 | 10:44 PM
coletrickle350's Avatar
I believe they do make a csi for our cars but i have a meziere and its goin on 3 years not a prob and every body i know that has had one loves it. Stick with what works I always say. And just spend the money on a 1le elbow there only like 50 bucks, well worth it i think.
Old Apr 5, 2003 | 10:54 PM
now there is no need to do the bashing. Both pumps have proven there worth
ANY part can have problems at one time or anouther. i find 90% of the problems with either pump is how it was installed
Good luck
Old Apr 5, 2003 | 11:00 PM
1FASASZ's Avatar
http://store.summitracing.com/defaul...art=csi-901lt1
Old Apr 5, 2003 | 11:33 PM
Lunarson's Avatar
I got the CSI for the lower price and it advertises up to 5500 hours compared to 2500 hours from the Meziere. I figure the quality is about the same. I've heard they were built by different divisions of the same manufacturer.
Old Apr 6, 2003 | 03:16 AM
Joe Brodman's Avatar
GP Moderator
Exclamation
Let's see:
- CSI is a far bigger name than Mezeire.
- CSI is SIGNIFICANTLY cheaper
- Both have had failures, but just take a good long look on the track record of both on this board, and you'll see why the CSI is the better choice
Old Apr 6, 2003 | 08:32 AM
joeSS97's Avatar
I know what you mean,Jegs list it for 93-95 lt1.That is wht you want,trust me ,thats what I used.One flyin z has it right,.
Old Apr 6, 2003 | 11:00 AM
tubby's Avatar
just wondering if anyone else has thier meziere hitting their pass side fan?
Old Apr 6, 2003 | 01:57 PM
Lunarson's Avatar
Its a common problem, I've heard most people just trim the section of the fan guard to add clearance.
Old Apr 28, 2003 | 01:44 AM
Dave88LX's Avatar
only 2500 hours? That doesn't seem like an awful lot
WTF?
