again offroad pipe?????
Old Apr 6, 2003 | 01:48 AM
lattmier's Avatar
A member posted that tbyrne is giving 0.1 off its slp items until the 4-30....I cheked it out...So I think I will order the SLP loudmouth exhaust and the offroad pipe from jds performance.....I think I can put the lm on with me and another freind....but the question is can I put the offroad pipe on bymyself, and if not what can i do if no one else will put it on becasue of lega concerns.....i have asked everyone, they wont touch it...could I put it on>>>>>?
Old Apr 6, 2003 | 03:27 AM
lattmier's Avatar
bump......i will check later
Old Apr 6, 2003 | 03:34 AM
D James's Avatar
It sounds like you've looked a little, by calling some shops. If you tell them its for off road use, you can probably find someone to do it. Most will install one, as long as you have cut the cat out yourself, as it is against the law to do so, unless its cloged etc. and being replaced by a new one. You could easily just go up to the auto store and find a sutible piece of pipe and put clamps around the pipe at each end to hold in place. I'm not sure how the ORP from companies is like, I would ask if it can be bolted in or if it must be welded in.
Old Apr 6, 2003 | 04:09 AM
lattmier's Avatar
ill check into that......I never thought of clamping the piece on to the existing pipes on either side...I may do that...thanx
Old Apr 6, 2003 | 09:50 AM
pickerman's Avatar
off road pipe
mine is a 93z28.Heres how I got mine.Took new cat off(sitting on shelf waiting for emmisions test). got piece of 17 and a half inch long, half inch pipe. Tell the shop to flare the ends out to go over half inch. put clamp on both sides. check for leaks.Your good to go. BIG improvement over damn cat. Pickerman
Old Apr 6, 2003 | 10:09 AM
DarkHorse's Avatar
Loudmouth has a female ball flange. You'll have to have your ORP male ball flared and then you should be able to bolt it up.
Old Apr 6, 2003 | 12:05 PM
Z28ROC's Avatar
If you have acces to a welder. I made this in my garage. I can swap this and my cat. converter out in a few minutes. www.z28roc.cz28.com/Bullet.jpg
www.z28roc.cz28.com/Bullet1.jpg
Old Apr 6, 2003 | 12:15 PM
Wild1's Avatar
I bought the ORP which was made by MAC. Took it to a custom fabricator in So Cal. Then, he removed the cat, sized it up, ground the edges and welded an adapter piece. When it was completed, he removed it and replaced the original cat. So, I can now have the interchangability to swap between the two... at the track.
Old Apr 6, 2003 | 05:54 PM
frankjr8's Avatar
lattmier
I am looking for an off road pipe also bolt on for a 96 Z.
Where is
Old Apr 7, 2003 | 01:56 PM
Wild1's Avatar
Here is where I got mine... it is a MAC
http://www.speedconcepts.net/late_mo...ers_Ypipes.htm
Great Customer Service.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
