Descreened MAF today got some ?'s
Old Apr 5, 2003 | 07:33 PM
speed76demon's Avatar
Alright today i changed my oil and desreened the maf. Now my oil pressure is pretty high i mean like just puttin around its like at 60 and now i have some water leaking out of my muffler very small hole, but there is water comin out. Would the maf cause that i made sure not to damage anything. I know prolly just a dumb ? but just wondering. Also I need a catback whats a good one??
Old Apr 5, 2003 | 08:02 PM
LT1ponykilla's Avatar
Descreening the MAF doesnt do anything. I had mine descreened and now i have a new maf and there is no difference.
Old Apr 5, 2003 | 08:25 PM
BPS's Avatar
BPS
No the MAF would not impact muffler or oil pressure.
Lots of good catbacks out there - depands on your budget and the level of noise your looking for - I'm very happy with my Borla.
Old Apr 5, 2003 | 08:40 PM
97silverz28's Avatar
Are you sure you drained all the old oil out?
Dont like Borla, too much $$
Old Apr 6, 2003 | 08:12 AM
joeSS97's Avatar
Putting in fresh oil will raise the pressure.It flows better ,especially when cold.The water coming from your muffler is normal.Condensation from the difference in temperatures.So your car is fine.Enjoy!
Old Apr 6, 2003 | 03:25 PM
Re: Descreened MAF today got some ?'s
What viscosity oil did you use? Did you follow the manual and use 5W-30 or 10W-30?
When you burn gasoline, you get two main products in the exhaust.... carbon dioxide and water. When the exhaust system is cold, the water condenses and will leak out the weep hole that is included in many mufflers specifically for that purpose.
Old Apr 6, 2003 | 04:59 PM
Dr.Mudge's Avatar
For every gallon of gas you burn, the cat is supposed to spit out a gallon of water.
Newer and colder oil should raise the pressure a bit over before, if you went thicker than before then it would likewise raise pressure more. If it is highly abnormal pressure, the filter could be dead.
Peytons'z
May 6, 2021 09:25 AM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
Jul 10, 2015 02:23 PM
CARiD
Jul 7, 2015 08:19 AM
