Where to get neutral balanced flexplate
Old Apr 5, 2003 | 10:46 AM
94ZVert's Avatar
I'm dropping a 396 that was originally in an M6 into an A4. I know that I need to get a neutrally balanced flexplate to complete the install, but where is the best place to get one and are there any specifics I need to consider when picking one? Thanks.
Old Apr 5, 2003 | 06:53 PM
badass383's Avatar
Good luck, I couldn't find one had to have one balanced by my shop.
Old Apr 5, 2003 | 07:23 PM
94ZVert's Avatar
How exactly did your shop balance it? The engine is already internally balanced, so what would have to be done? I've searched and can only find externally and internally balanced ones. Could a shop neutrally balance an externally balanced flexplate? Thanks.
Old Apr 6, 2003 | 08:37 AM
94ZVert's Avatar
Anyone?
Old Apr 6, 2003 | 09:29 AM
bad79z28's Avatar
A good machine shop should be able to remove the balance weight from the flexplate, then neutrally balance it. I've done this myself...on a F*rd.
Kevin
Old Apr 6, 2003 | 10:28 AM
TedH's Avatar
I have the original flex plate with the weight removed. I couldn't find a neutrally balanced one anywhere.
Old Apr 6, 2003 | 11:48 AM
94ZVert's Avatar
So there should be no problem reusing my original flexplate then? Thanks for the replies.
Jeff1904
Jun 5, 2016 05:00 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
4586
Aug 18, 2015 07:08 AM
bunker
Aug 1, 2015 10:10 PM
