Messed up Threads on Exhaust Bolt
Old Apr 4, 2003 | 02:09 PM
Laymaster's Avatar
I'm putting on headers and I kinda started a bolt wrong and kinda screwed up the threads a little bit, basically I can't put the header bolt in. It's not horridly stripped just the beginning. How do I fix this, and about how hard is it to do? Thanks.
Old Apr 4, 2003 | 02:22 PM
Shankels94TA's Avatar
If its on the drivers side then you may be able to clean the threads up with a tap and die or get a heli coil installed like im gonna have to. If its on the passenger side......well....your gonna have to live with it or pull the head. Hope this helps, good luck!
Old Apr 4, 2003 | 02:43 PM
1997rblckSS's Avatar
your gonna have to retap it, no other solution.
Old Apr 4, 2003 | 03:15 PM
Laymaster's Avatar
how do you 'retap it'
Old Apr 4, 2003 | 04:16 PM
joeSS97's Avatar
Take the bolt with you to a good hardware or auto parts store and buy the correct tap.Put it in the hole straight and turn it a quarter turn at a time,reversing it slightly to clear the threads and spray with oil as you go.Good luck and take your time.
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
95chwagon
Feb 28, 2015 12:02 PM
moparman
Feb 11, 2015 08:29 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
