Anyone with Long Tubes on a Convertible??
Old Apr 5, 2003 | 07:27 PM
PoorMan's Avatar
I am once again reconsidering buying another set of headers after all the great pics I have seen of the Jet Hot LT ground clearance. I have a borla cat back and it looks like a y-pipe can be made that will not require cutting or modifying the borla cat back pipe. The pipe has a slip fit connection about halfway back. Anyway, I was wondering if any convertible owners out there have had any clearance issues with Jet hot lt's hitting the convertibles crossbrace once the y-pipe is on. The pictures I have seen on coupes tuck up so close to the pan that I am concerned that the crossbace may interfere.
Jeff D.
Old Apr 5, 2003 | 08:20 PM
LPE Z convt's Avatar
I have a 95 convertible and i have hooker LTs and mufflex y-pipe with borla cat back everything fit perfect but you will have to cut a small bit of the brace at the corner nothing big no real clearence problems at all.....
Old Apr 5, 2003 | 08:33 PM
PoorMan's Avatar
Thanks for the reply. Did the mufflex y-pipe slip into the borla pipe or did you need to fab a section of pipe?? I would really like to see a pic of your y-pipe intalled if you have one laying around.
I am not sure if jethot increased the ground clearance over the hookers or not. I have a few pics of jet hots on cars and their collectors look like they are really close to hitting the pan. The hookers I have seen look like they have several inches. Maybe a mirage though.
Jeff D.
Old Apr 5, 2003 | 10:35 PM
redtransam5674's Avatar
yeah i would like to see some pics of your y-pipe. i have a 95 convert and was thinking of going with get hot and a mufflex y-pipe. but want to know if it will clear all the bracing. and how much gound clearance did you loose with the headers? and with the y-pipe???? thanks
Old Apr 5, 2003 | 10:41 PM
PoorMan's Avatar
redtransam...
I have three good pics that show ground clearance shots of hooker lts with the mufflex y-pipe. If you want them I can email them to you. I am trying to find out if the Jethots have the same ground clearance though. I think jethot improved on it some.
Jeff D
Old Apr 6, 2003 | 12:20 AM
TonyJ's Avatar
With my BRM welded subframe connectors, I decided to remove the cross-brace for maximum clearance. It also allows you to mount a driveshaft loop in the holes formerly used by the brace. This is how the coupes are setup and it's fine with the subframes. Great clearance in you get a custom y-pipe built.
Old Apr 6, 2003 | 06:20 PM
poor man.
could you please send those header clearance pics to my e- mail. thanks. i want good ground clearance.
Old Apr 7, 2003 | 11:01 PM
PoorMan's Avatar
Np. Pics sent.
Jeff D.
Old Apr 8, 2003 | 12:41 AM
Green G0blin's Avatar
Poorman: can you please send me pics too please?
GreenGoblin@kukamail.com
or redtransam: forward them please?
Old Apr 8, 2003 | 06:32 PM
green hit me up on fbody.com i will post them there for you.
RUENUF
Mar 13, 2016 03:39 PM
StansZ28
Feb 19, 2015 07:39 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
