Mystery sensor? Any clue?
Old Apr 6, 2003 | 08:53 PM
BigDaddy's Avatar
I finally pulled the motor out of my 96 TA. I noticed that on the passenger side of the motor there is a sensor that is part of a freeze plug. Does anyone know what this is? My new 383 shortblock doesn't have the sensor, just a regular freeze plug.
Old Apr 6, 2003 | 09:09 PM
Freeze plug or block drain? A freeze plug is around 2" around and up on the side of the block. It is the knock sensor if it is in the drain hole location (close to the bottom middle of the block).
If it is in a freeze plug location above the starter, it is the engine block heater, optioned on cars in cold climates.
Old Apr 6, 2003 | 10:39 PM
BigDaddy's Avatar
Thanks Shoebox. It's the Freeze plug. I forgot that I had the engine block heater. I've never needed to use it.
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
NewsBot
Jul 29, 2015 08:10 PM
Boss002
Jul 24, 2015 10:47 AM
Noct
Jul 14, 2015 01:18 AM
