What MSD Coil Replaces The OEM Coil?
Old Apr 6, 2003 | 10:41 PM
Rich_z28's Avatar
I've been having some electrical spark problems and was going to replace the the Opti, but have decided to replace the coil first. I'd like to replace the OEM coil with an MSD coil, but am unsure on which on will work? I don't have an MSD ignition, but still want to use an MSD coil. I was looking in Jegs at the MSD Blaster Replacement Coils. (Jegs Part# 121-8266). Will this one work? If not which one will? Thanks.
Here is a description of the coil. Also, the actual coil I think I need is pictured at the top of the page.
http://www.jegs.com/cgi-bin/ncommerc...73&prmenbr=361
Old Apr 6, 2003 | 10:50 PM
121-8226 Blaster GM Dual Connector Coil for your 1995. It will directly replace your factory coil. No other MSD box needed.
Old Apr 6, 2003 | 10:54 PM
Rich_z28's Avatar
Thanks Shoebox. I thought that was the one I needed, but wanted to ask just to be sure. Thanks Again!
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
maybe2fast
Feb 5, 2015 05:14 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
