Anyone have pics of the ls1 brake upgrade?
Old Apr 6, 2003 | 02:29 PM
tryme96Z's Avatar
I need a pic of how to make the brake line fit. I have the LS! lines.
Old Apr 6, 2003 | 06:28 PM
Birdie2000's Avatar
I used a cutting disc on an angle grinder to cut a groove in the bracket, and then hammered it down so the brake line attaches facing the caliper instead if facing up. This worked perfectly with stainless braided lines that were designed for LT1 brakes. If you're desperate, I can get pics.
Old Apr 6, 2003 | 11:47 PM
tryme96Z's Avatar
Thanks! Anyone else have any input.
Old Apr 7, 2003 | 12:28 AM
PatsTA's Avatar
I just did this last weekend, and did what Birdie2000 said, but I re-used the LT1 lines. I removed the bracket, then used a dremel to cut it, then hammered away until it was nearly 90 degrees. Here is another thread on this:
http://web.camaross.com/forums/showt...threadid=87703
The 7th post has a good picture of the bent bracket.
Patrick
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
