help-replaced h2o pump,no fire @ coil?
94Z, I just replaced my water pump, and it turns over, but won't start. There is no fire off coil wire going to optispark. the coil is plugged in. Please dont suggest taking it back apart, my nuckles are trashed. Thanks!
Did you get the coil wet by any chance... before, or during, replacement? I had to replace my water pump once because the pressed hose was leaking and it was dripping onto the coil. Unfortunatly, it ruined the coil too.
I hope that's not what it is but its a thought. Good luck.
Jason
Jason
grabbem88
Mar 18, 2015 01:25 PM
