Looks like I'm pulling the motor...
Old Apr 4, 2003 | 06:53 PM
'94 Bad A Z28's Avatar
Angry Looks like I'm pulling the motor...
Driving around today, and I was noticing a slight tick... Had a buddy with me and he heard it to. It sounded like a rocker arm was lose, so we were gonna tighten it up a little later...
Turn on to U.S. 1792 from 436 get on it to not even half throttel(sp?) and all the sudden it sounded like the nut on the rocker cam all the way off and the rocker slipped sideways...
Shut her down and coast in to a parking lot. Pull the valve cover and what do we see, nothing... Everything looks perfect. Started her up with the valve cover off, and everything was moving the way it should be...
So it's not a bent push-rod, not a lose/fallen off rocker... What do you think it could be? Maybe rings?
I can't really describe the sound... You can hear something like air passing through the cylender as the pistons move up and down... Kinda sounds like a huge exhaust leak.
Old Apr 4, 2003 | 06:57 PM
Grease's Avatar
It could be alot of things but before you pull the engine try a compression test
Old Apr 4, 2003 | 07:25 PM
I'll be doing that either tomorrow after work, or Sunday.
Old Apr 6, 2003 | 03:13 PM
Figured it out, blew a plug out of the head.
Old Apr 6, 2003 | 06:27 PM
cop01's Avatar
be glad thats all it is. It could have been a LOT worse. your one lucky man.
Old Apr 6, 2003 | 06:39 PM
Grease's Avatar
Ah! You see.
Old Apr 6, 2003 | 06:48 PM
Dave88LX's Avatar
You're lucky! I wish that was the cause of my noise
http://paradox.shacknet.nu/dave88lx/formula/clack2.mpg
But my oil pressure is way dropped, so I knwo it's not a plug
2QUIK6
Sep 17, 2016 02:31 PM
jbert55
Oct 31, 2015 03:52 PM
Cam's maro
Aug 11, 2015 07:45 AM
whitehooptie
Aug 10, 2015 07:02 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
