Knock Module & Coolant Drain Plug Removal
Old Apr 4, 2003 | 05:30 PM
AENIMA95z28's Avatar
How do i get the knock module off ?
The drain plug is in there so tight i dont want to break it off like i did on the y pipes. Any advice
Old Apr 4, 2003 | 05:44 PM
dreamer1q's Avatar
Re: Knock Module & Coolant Drain Plug Removal
The knock module just screws into the block. I believe it is a 7/8 wrench. I just did mine yesterday. The drain plus is the same way. Just screws in. I doubt you will break it, they are very stout, but they do cease into the block. Put your butt muscles into it, and it will come out. Use a little anti sieze when you put them both back in.
Q
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
HectorM52
Mar 15, 2015 10:45 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
