Ball Joint Question
Old Apr 5, 2003 | 10:54 AM
93ZM6Tally's Avatar
Ball Joint Question
Just bought ball joints from Advance Auto parts. I bought both lower and upper ball joints. The uppers were expensive, about 50.00 each, and they are the sealed type without a grease fitting. The lower units do have a greasable fitting. I was under the impression that both upper and lower were available as greasable fittings. BTW these are TRW Federal Mogul parts, which I was led to believe were the "good" ball joints. Did they give the incorrect upper units?
Old Apr 5, 2003 | 11:02 AM
n2ceptor's Avatar
there are ball joints available with or without(prepacked) grease fittings.... I dont know if there is a difference in life..... If there is a hole on top where it looks like a grease fitting goes then you need the fitting.... But if it is soild then no prob.You just dont have to worry about greasing the top ball joint.....
Victor Lamb
Aug 26, 2017 02:52 PM
blac94Z
15
Mar 2, 2015 12:00 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
ModdedNerd
Dec 10, 2014 08:42 PM
91 Redd Sledd
Aug 4, 2002 10:47 PM
