160 deg t-stat?
Old Apr 4, 2003 | 05:13 PM
speed76demon's Avatar
160 deg t-stat?
How many people had a prob with runny hot after install i have heard of several with this prob should i just plan on buyin a fan switch with it or what??
Old Apr 4, 2003 | 05:17 PM
norcalstreet's Avatar
You won't get the full cooling effect without a PCM reprogram, or manual switch. The coolant will flow out of the stat at 160 degrees but the cooling fans won't trigger until around 195 or 210. When accelerating on a freeway or open road there's more air being pushed through the radiator which will cool more with a 160 stat. However, to get a constant 160 temp you need to have the PCM reprogrammed.
Old Apr 4, 2003 | 05:26 PM
Some people initially run hot after the install because they don't get all the air out of the system. Otherwise there is no problem. A fan switch is not mandatory. Having the fan ON temps reprogrammed like norcalstreet said, helps keep temp down at all times.
G-BODYT56
Jan 14, 2022 11:14 PM
chevy94c
Mar 26, 2016 08:53 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
tdigger9899
Sep 7, 2015 10:56 AM
