Almost done this friggin V8 swap, need some help...lt1 guys...
Old Apr 30, 2008 | 11:05 PM
JooneJune's Avatar
For most of you, you know I'm doing a V6-V8 swap. I've been lally gagging and haven't worked on the car since Feb.
If you remember I was having electrical demons.(no fuel prime, no spark) TODAY I swapped out the underhood fusebox harness (lights,rad) and the internal dash harness all the wy back to the tail lights. Underhood is off a loaded 94z (same as engine harness off a 94z) dash harness is off a 3.4L 94.
When installed the dash harness, and underhood. I rewired the turnsignals with a newer version(95 bulb holders insted of 94) but the wires are the same, lt blue, brown, and black. The old underhood harness had a goofy alarm system that was cut out.(had a remote start...could be a problem?) but once i reinstalled the battery I had ACC and fuel prime.
------------------CLIFF NOTE PORTION HERE:-----------------------
Here's the deal, after the install I do a light check to find my running lights don't work front and rear, fogs don't work, highbeams don't work, turnsignals don't click (or light up). The regular headlights lights come on (when switched on) and the interior lights come on. THE FUEL PUMP PRIMED!!! yahoo! who needs lights... lol jumps up to 30psi and falls with time. (normal? Leak somewhere?) Before the harness swaps everyhting worked perfectly)
---------------------------END-------------------------------------
I'm thinking its a fuse (what do you think), I was frustrated so I packed up for the day. Figure once thats done, I need to realign my rear (driveshaft is not on right) Finish the brakes, swap out the NEW bent flywheel (FK!), throw on my MT's and break in the motor. I'm super excited (considering we are gong on 3 years now... fK!) Reinstall the dash/interior parts, and finish the cooling system. Anyhelp you can provide would be great. Thanks!!!
Old May 1, 2008 | 07:51 AM
JooneJune's Avatar
Bumpity... inj.... lol....
Old May 1, 2008 | 08:45 AM
1) Engine questions only on LT1/LT4 Engine Tech.
2) You already have this on the "General ....." forum. Do not post the same problem on multiple forums.
3) Do not force your posts back to the top in less than 24 hours. Read the "sticky" at the top of the forum listing.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
