low antifreeze???
Old May 1, 2008 | 04:30 PM
96blackLE2's Avatar
low antifreeze??? water in oil???
let my car sit through winter and forgot to check the antifreeze mix... had water and antifreeze mixed, but have no idea what it was... now after running it have milky oil.... could i have frozen the block and cracked a head or warped them or something??? headgasket??? at first it was fine but after a couple days noticed a little white smoke once in a while out of exhaust and can smell the antifreeze.... wouldnt a freeze plug pop before the block would crack if that was the case?? no leaks or anything... pulling it apart to replace heads and cam... any ideas????
thanks
jeremy
Old May 1, 2008 | 06:51 PM
ricehammer's Avatar
Sounds like one of the head gaskets.
Old May 2, 2008 | 03:14 AM
96blackLE2's Avatar
thanks i hope it is just that
Old May 2, 2008 | 01:43 PM
96blackLE2's Avatar
does everyone agree that its prob a head gasket????
Old May 2, 2008 | 02:10 PM
ss.slp.ls1's Avatar
Sounds like it to me.
And from what I have read, the term "freeze plug" is incorrect, they weren't put there for that purpose. The are called "expansion plugs" but they are really just holes left by the casting process which are then plugged.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
