"Unknown coolant loss"
Old Apr 27, 2008 | 08:48 PM
LJM97Z's Avatar
I noticed my low coolant light came on the other day, found the coolant was low in the radiator about 3-4 inches, light went out & stayed out, but on my way home from the track it came back on about 15 miles from the house (total round trip 120 miles), i checked the fluid this morning & it is down a good 8-10 inches in the radiator, i can't find ANY leaks anywere, the pass floor is dry, i don't smell antifreeze while in the car, the oil is nice & clean, so i'm stumped , i'll re-fill it again & see what happens, any idea of what to check?
Old Apr 27, 2008 | 09:08 PM
NukeFPE's Avatar
Is your overflow tank full? If so, change your radiator cap ~ the valve is not allowing the water to be pulled back ~ I've had this happen twice on my 94 Z (180,XXX miles).
Old Apr 27, 2008 | 09:33 PM
Red93Camaro's Avatar
180,000 miles huh! wow thats nice, now I'm not so worried about my car goin soon 111,xxx miles. I thought these died around 150k
Old Apr 27, 2008 | 09:37 PM
caldercay's Avatar
??? These are V8's - of course they wont last if they're dogged. I've
had a V8 go over 300k miles and a V6 go over 225k miles. The Z
has 156k miles now and she's still really strong!
Old Apr 27, 2008 | 09:41 PM
brianswimmer23's Avatar
as long as you keep up regular maint then it should go as long as you keep on top of it!! i know a few guys here in tucson that have close to 500k miles.
Old Apr 27, 2008 | 09:47 PM
LJM97Z's Avatar
I think this might be the cause, because the overflow is full & the cap looks old, i'll change it tomorrow.
Now that we have gotten on the subject of mileage lol, my pig has 157,XXX on it, & just pulled off a 13.7 @ 101 last night on a so-so 2.17 60ft. with street tires & bolt-ons , these are by far a great engine, especially if there taken care of like this one was.
Old Apr 27, 2008 | 10:36 PM
SnakeOiler's Avatar
It also could be the overflow hose and/or grommet causing a leak, thus not letting the coolant to be sucked back in - instead it is sucking back in air.
Old Apr 28, 2008 | 12:31 AM
MadMike 97 Z28's Avatar
start looking for steam out the tail pipes. im afraid those were my exact symptoms when i blew my head gasket. im in the process of installing a cam and other upgrades since i had most of the engine disassembled.
Old Apr 28, 2008 | 12:41 AM
ss.slp.ls1's Avatar
I would borrow a pressure tester from AZ and look and listen for leaks.
Old Apr 28, 2008 | 12:48 AM
Ironxcross's Avatar
500k?! I find it hard to believe but i guess it makes sense if you keep up with everything and do a lot of preventative maintenance.
Old Apr 28, 2008 | 06:59 AM
LJM97Z's Avatar
No steam in the pipes, no water in the oil neither, doesn't run hot, no exhaust smell in the radiator.
Old Apr 28, 2008 | 01:22 PM
Slowmaro95Z28's Avatar
I had a problem like this and after thinking I blew a head gasket I noticed there was a crack in my rad on the tank under where the cap is. There was no coolant smell and it never left a puddle. The crack was so small only steam got out when I was driving. I felt like an *** for missing it for a few months but I was happy to see it wasn't anything major.
Old Apr 28, 2008 | 05:43 PM
93DGTA's Avatar
Check the hose under the battery thats where mine was going.Was showing no signs of leaks or anything sitting
Old Apr 28, 2008 | 08:19 PM
MeanGreen97Z's Avatar
Some cars have problems with the head gaskets....
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
