question about plugs
Old Apr 28, 2008 | 11:39 PM
rock1501's Avatar
lets say I ran a plug one or two heat ranges higher than i was suposed to.What could happen?
no nitrous but its a high comp motor(almost 14:1)
Old Apr 28, 2008 | 11:51 PM
Orr89rocz's Avatar
could leave too much heat in the chamber and burn the plugs up. they could get so hot they could predetonate the charge.
Inspect them for detonation but for high compression motors you want a colder plug to keep chamber temps down
what plugs you running?
Old Apr 28, 2008 | 11:58 PM
rock1501's Avatar
Ngk 5672a-8
Old Apr 29, 2008 | 12:25 AM
Orr89rocz's Avatar
thats a good plug for racing... you should be ok with it. I dont think your too far off heat range wise. other recommended ones would be 9 or 10 heat range rating.
for alot of street use and not high rpm racing, a hotter plug is better. keeps less fouling but on a race motor, it will get too hot. so colder is better
Old Apr 29, 2008 | 12:36 AM
rock1501's Avatar
ok so since it is a race only motor and it does see over 7000 rpm I might change to the 10 heat range and see what happens
grgguy
17
Feb 23, 2015 07:57 PM
blac94Z
Feb 23, 2015 04:29 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
rwferguson43026
Feb 6, 2015 10:06 AM
cmdeshon
Dec 27, 2014 10:06 AM
