check engine light
Old Apr 30, 2008 | 12:45 AM
Maverick_997's Avatar
check engine light
does not come on when i turn the key on. scanner not bringing up any codes saying the bulb is bad or removed. what else would cause this??
Old Apr 30, 2008 | 07:09 AM
Is it possible the bulb has been removed and relocated where it is still plugged in, but no longer visible through the dash face?
What are you using to scan the PCM?
Old Apr 30, 2008 | 02:04 PM
i used the inovia scanner and it didnt bring up the codes but im going to look into the "it might have been moved" and see if i can find it
Old Apr 30, 2008 | 03:04 PM
I have an old Suzuki that has a piece of "invisible" black tape over the "check engine" light......
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
