coolent level sensor HELP
Old Apr 30, 2008 | 07:41 PM
stugots's Avatar
I have a 94 Z28, the coolent light is on even tho its full, I have read many threads about this issue but im having a problem finding where to buy a sensor, Chevy tells me there 2 "diffrent kinds" for this same year and they CAN'T get one of them.
I only found the sensor at autozone but I wont but duracrap on my car can anyone help me here? link where to buy the correct one or SOMETHING?
Thanks alot guys
Old Apr 30, 2008 | 07:52 PM
andysc's Avatar
Just unplug it and be done with it. They are common to fail, so why bother. Just my 2 cents worth.
tia
andy schuck
Old Apr 30, 2008 | 08:28 PM
caldercay's Avatar
Originally Posted by stugots
[snipped] I only found the sensor at autozone but I wont but duracrap on my car can anyone help me here? link where to buy the correct one or SOMETHING?
Oreilly:
Borg-Warner S8222
RockAuto:
AIRTEX # 5S1449
Standard Motor Products # FLS24
Old Apr 30, 2008 | 08:31 PM
caldercay's Avatar
Yea, and when your system level drops uncomfortably, you'll wish you
hadnt disconnected it. If no water runs across the gauge temp sensor,
it doesnt properly read "hot air" and may show everything is fine.
Old Apr 30, 2008 | 08:47 PM
stugots's Avatar
thats why i wanted to have one I have heard horror stories about head gaskets.
Thanks for the part numbers its a HUGE help, I've been going nuts
Old Apr 30, 2008 | 08:53 PM
stugots's Avatar
so there is only 1 type??
Old Apr 30, 2008 | 08:56 PM
caldercay's Avatar
I plugged in "1994 z28" and they only showed one part # - heck, it
might even be the same part # i got for my Z (I got the B-W sensor).
Old Apr 30, 2008 | 08:58 PM
wrd1972's Avatar
unplug it.
Old May 1, 2008 | 08:53 AM
Did you try cleaing the old one? Sometimes that will help.
Shoebox shows two different GM part numbers in his parts list, based on the harness plug:
1994-1997coolant level sensor (2 way plug) - 10096163
1994-95 coolant level sensor (8 way plug) - 12135027
For future reference on part #'s:
http://shbox.com/1/Parts.htm
Old May 1, 2008 | 10:35 AM
Ironxcross's Avatar
Thats why you check it. Just like you should check your oil. Or your tire pressure. Its a good idea.
and for the OP, disconnect it, those parts are junk
Old May 1, 2008 | 10:40 AM
2000GTP's Avatar
Freak occurrences can happen too where a periodic check will be of little benefit. Considering what a new sensor costs or even the possibility that the old one can be cleaned and made functional, I don't see the big deal in fixing the problem.
Old May 1, 2008 | 10:43 AM
To the OP... if you want to keep it, keep it. Its your car, do what you want with it.
Old May 1, 2008 | 12:07 PM
Though the book lists one with an 8 way plug, I have never heard of anyone ever having one.
Old May 1, 2008 | 12:15 PM
My 94 only has the 2-wire.
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Fusion93Z
Jul 27, 2002 10:48 PM
