Gasket Package for Cam Change
I heard you can normally salvage your old Valve Cover gaskets, and save about $60 on gaskets.
Is that true? If so, is it cheaper to just but all the gaskets separately and not buy the head gasket opposed to buying the Cam Change Gasket Pack from Thunder Racing?
Try some intake gaskets along with this: http://www.partsamerica.com/ProductD...pe=106&PTSet=A
It would be a good idea to change the front cover seals when you remove the timing cover.
http://www.partsamerica.com/ProductD...tNumber=CS9966
http://www.partsamerica.com/ProductD...pe=102&PTSet=A
I have never needed to replace valve cover gaskets but they could tear on you.
What hassle, I gave him 2 part numbers available local almost anywhere in the country at a great price roughly $$35 less without shipping once you throw in the valve cover gaskets.
http://www.partsamerica.com/ProductD...pe=107&PTSet=A
They frequently have free shipping over $50 or 10% order online pickup in person.
Reason I recommend the full bottomend gasket set is so you can pull the pan completely and replace the oilpump driveshaft with an all metal one and consider a higher pressure spring in the stock oilpump. I wonder how many LT1s have spun bearings because owners who thought they were careful dropped debris in the oilpan. I like to completely remove the engine, then again that is farily easy on my car.
The pan removal is a little more difficult with the f-body, but the benfits would be well worth it.
Would it be safe to say that for a head and cam swap I could purchase the two parts america part numbers above (the conversion kit and the intake kit) and add the head gaskets of my choice and I would be covered on gaskets?
Got a head and cam swap coming up and I need the gaskets, and this looks like a good deal.
Jeff
Jeff
Looking at the gasket kits more closely, can I just get the timing cover set instead of the conversion kit if I am not going to pull the oil pan? I dont think I have a use for most of those gaskets. Looks like there is a rear main seal oil pan gasket ect. I dont think I will need.
Jeff
Jeff
