What causes a ring land to break???
Old Apr 27, 2008 | 07:13 PM
95LT1Z28's Avatar
I have 86,000 miles on my '95 Z28. I recently had an oil leak that was leaking from the driver side valve cover, and a smaller leak on the passenger side valve cover. I replace those with new fel-pro gaskets. I also replaced my PCV valve since it was right there. Now when I go WOT the engine sprays oil out the dipstick tube and all over the headers. The PCV valve was a new one and rattles when you shake it. I am going to do a leak down test this week and see what I come up with. But my question is, I do not have a boosted car just a cam and bolt-ons. What causes a naturally aspirated engine to potentially break a ring land? Thanks for any input!
Jeff
Old Apr 27, 2008 | 07:35 PM
wrd1972's Avatar
detonation
Old Apr 27, 2008 | 07:37 PM
95LT1Z28's Avatar
I have never noticed any detonation from the motor and it has always run smooth up to 6300 rpm. Is there anything else it could be???
Old Apr 27, 2008 | 07:55 PM
LJM97Z's Avatar
You might have another issue with the crank ventalation, what you need to do is, while the engine is running, put your thumb over the PCV & see if its sucting a strong vacuum & the engine drops in RPM, if there is no suction, then something is clogged, this explains why your VCs were leaking, once you fized that, the pressure wen't elsewere (dipstick tube).
Old Apr 27, 2008 | 08:25 PM
96capricemgr's Avatar
A guy a little south of me had a ring land break last winter found it dangerously lean on the dyno while troubleshooting. Had a similar cam and more important to the discussion the same tuner. People don't like to hear it but pcmforless and detonation problems are frequently found together, particularly if you throw hacked up inconsistent heads into the equasion, though it does not look like you have that part of the problem.
Old Apr 27, 2008 | 08:54 PM
wrd1972's Avatar
Yup,
My mailorder tune was way lean too.
Old Apr 29, 2008 | 06:05 AM
cehan's Avatar
No complaints here about my PCMforless mailorder tune. It was a flat 12.5 when I put the car on the dyno. One thing I did have him do was to program in the BLM locker patch.
Old Apr 29, 2008 | 06:40 AM
CANTONRACER's Avatar
A lean condition can cause those issues...
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
Bxlt1
Sep 29, 2015 03:18 PM
