HP Estimate.
Old May 1, 2008 | 09:19 AM
yungin' w/a z28's Avatar
HP Estimate.
What would you guess I am sitting at with my recently added mods in my sig. I am hoping to get a MadZ28 tune later on.
Less signifigant things:
Bosch Platinum Plugs
Bosch Wires
Mobil 1 Fully Synthetic
What do you think?
Old May 1, 2008 | 10:01 AM
krillformula's Avatar
Depends on what cam is it?
Old May 1, 2008 | 10:37 AM
2000GTP's Avatar
Bosch Wires
What do you think?
Those recent add ons won't do anything. Also, whether you have an M6 or auto will make a difference. As mentioned above, the choice of cam will play a big factor as well as if any supporting mods were done with the cam such as 1.6 roller rocker arms.
Old May 1, 2008 | 10:44 AM
jay_rich's Avatar
Im gonna guess around 290RWHP. I had a hotcam, 1.6RR 52mmtb, lightly ported heads, ported intake etc and only did 311RWHP.
Jay
Old May 1, 2008 | 12:01 PM
I didn't think the plugs, wires, and oil would have an effect.
But with the headers and Magnaflow exhaust. That's what I'm curious about. I have no cats too.
I don't have any idea what cam is in it. If I knew of a way to check I would. I know its not a very big cam. It only has a small amout of lope to it. The guy I bought it from just said it had a different cam. That was it. If I would have known I was going to do mods to the car, I would have found out more.
Also, my car is an A4.
Old May 1, 2008 | 12:11 PM
2000GTP's Avatar
Jay
Thats probably what I would guess, maybe a little higher, maybe a little less, it is hard to judge without knowing the exact grind or other valvetrain details.
Old May 1, 2008 | 11:07 PM
1996camaroSSclone's Avatar
I dont know about you guys but I've heard nothing but bad results from bousch plugs.... I had them in my firebird when I first got it and it ran like ****. Now I have NGK and it runs like a champ. I use ac delco in my camaro and it runs fine.
Old May 1, 2008 | 11:16 PM
BCdawg57's Avatar
ive used bosch plugs before and they worked just fine for me.
Old May 2, 2008 | 08:42 AM
stugots's Avatar
am I the ONLY idiot that spends GOBS of money on the Irudium plugs?
Old May 2, 2008 | 11:14 AM
2000GTP's Avatar
I use iridium in my other vehicles, not in the Camaro though. I use a copper conductor for the nitrous. Nothing wrong with iridium plugs though.
Old May 2, 2008 | 11:46 AM
mdenz3's Avatar
As a general rule of thumb I wont use anything with "Bosch" on the box. Even the stuff they make for the German OEM's is junk.
For your question; 290 ish sounds likely. The easest way to get an idea of your cam would be to remove one of the valve covers and using a dial indicator measure the valve lift and duration. That wont tell you exactly but if it is an over the counter cam you could probably match up the specs.
Old May 2, 2008 | 12:25 PM
slomarao's Avatar
290-310rwhp, knowing something aside its an aftermarket cam would help us
Old May 2, 2008 | 12:42 PM
LSWHO's Avatar
I would bet it's a hotcam.
one wicked element
Jun 8, 2006 08:45 AM
