coil bracket?
Old Apr 22, 2008 | 07:47 AM
BLDun's Avatar
coil bracket?
I am getting ready to switch back from my LTCC setup to an MSD opti and when I did the original conversion I removed the coil bracket and evidently tossed it since I can't find it anywhere. I looked on Shoebox's site but can't find a part # for it. Anyone know where I can get one besides the dealer - they tend to overcharge for everything?
Old Apr 22, 2008 | 08:10 AM
There will be at least 2 parts to the metal bracket, 1 heat sink and the ICM. The brackets look to be no longer available. I would try a salvage yard or parts wanted forum.
Old Apr 22, 2008 | 08:27 AM
Ricardo's Avatar
I have bought a couple of them in ebay complete with coil, heat sink and ICM. Once I got lucky and got one for $25.
Old Apr 22, 2008 | 08:32 AM
maverickmk's Avatar
if you find any see if they have 2, I need one as well
here's just the ICM at GM Parts Direct http://www.gmpartsdirect.com/catalog/frameset.cfm
Old Apr 22, 2008 | 10:40 AM
BLDun's Avatar
I may have to go the salvage route. I have a MSD coil and ignition box so all I need is the mounting bracket for the coil. I'm wondering how hard it would be to fabricate one.
Old Apr 24, 2008 | 07:10 PM
BLDun's Avatar
How important is the heat sink and does it matter where the coil is located?? I am not going to use a stock icm but an MSD ignition box.
Old Apr 24, 2008 | 09:19 PM
The heat sink helps to keep the ICM cool. The ICM will not be replaced by the MSD box. You must use both. The coil should be as close to the opti as possible (like where it is).
Fastbird93
Apr 9, 2016 07:01 PM
maybe2fast
Mar 16, 2015 09:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
Lt1son
Dec 22, 2014 10:58 AM
