EGR question on a 96z
Old Apr 21, 2008 | 10:32 AM
91RSLT1's Avatar
I am in the process of putting headers on the 96z, my question is in regards to the EGR. Will the car throw a code or have any negative issues, if I block off the tube that runs from the pass. side header to the back of the intake ONLY? I will leave the parts of the egr system intact and not have the EGR tuned out of the computer.
Old Apr 21, 2008 | 12:51 PM
It might if the PCM does not see a corresponding change in O2 readings when the EGR is activated.
Old Apr 21, 2008 | 01:37 PM
lovescamaros25's Avatar
Considering you have an OBD2 vehicle...I would say yes,most likely you will throw a DTC.
Old Apr 21, 2008 | 02:19 PM
The PCM cycles the EGR valve, and looks for the corresponding change in manifold absolute pressure (MAP). If the EGR riser tube is blocked off, the MAP will not change, and you will get likely a code.
Old Apr 21, 2008 | 02:50 PM
91RSLT1's Avatar
Ok I guess I will just leave it on to avoid any headaches. Thanks guys.
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 18, 2014 12:57 PM
