What did I just break?
Old Apr 26, 2008 | 06:44 PM
The $6 Man's Avatar
Is this the oil pressure sensor?
[IMG][/IMG]
Old Apr 26, 2008 | 06:49 PM
rcantrellz28's Avatar
Thats the oil level sensor, the pressure sensor is the one thats on the back by the intake manifold
Old Apr 26, 2008 | 06:50 PM
Looks like it. Yours is a 1993 or early 1994?
Old Apr 26, 2008 | 06:51 PM
No, you can clearly see the level sensor on the pan in that picture.
Old Apr 26, 2008 | 06:52 PM
Sorry, I thought thats the one he was implying.
Old Apr 26, 2008 | 06:54 PM
Lol, I assumed it was the thing hanging down. I guess it needs clarification.
Old Apr 26, 2008 | 07:03 PM
The $6 Man's Avatar
Yeah, the thing hanging down, the rest of it is in the block. It's a 94. I'm guessing there's a connector inside this insulator?
Old Apr 26, 2008 | 07:08 PM
There should be a wire/connector going to the op sensor that is located just above the oil filter on the side of the block.
Old Apr 26, 2008 | 07:21 PM
neversummer's Avatar
Yes it is the oil pressure sensor. I broke mine too, so don't feel bad. Pull that insulator back and you will see it. I don't remember if I got a new one at Autozone or dealer only.
Old Apr 26, 2008 | 07:25 PM
The $6 Man's Avatar
Thanks for the help guys, I broke it installing some headers. Also broke the coolant temperature sensor connector when removing it . I guess plastic gets brittle 14 years later!!
Old Apr 27, 2008 | 04:40 AM
SS RRR's Avatar
when replacing it make sure to get the correct one. there are two different part numbers between the PCM temp sensor (in the waterpump) and the one tapped into the side of the head. shoebox has the part numbers on his page.
Old Apr 27, 2008 | 06:32 AM
94zgreenmachine's Avatar
I broke mine 3 times. I don't mess with it enough to remember how to take it off. It seems to break very easy. It broke once with my Header install.(8 yrs ago) 2. When I built the 383 (4 yrs ago)and 3. Just last month for a tear down of my current set-up.
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Aug 17, 2015 09:50 AM
Cam's maro
Aug 11, 2015 07:45 AM
