383 cutting out after gets hot.
Old Apr 21, 2008 | 12:38 PM
kline454's Avatar
Well my car keeps cutting out after it gets hot i have replaced the plugs wires,injectors,opti, it acts like its loading up on fuel,just starts missing and poping out the exhaust last night it even died. does this sound like a ICM??
Old Apr 21, 2008 | 01:00 PM
WS Sick's Avatar
I would get a scanner and see if it all starts after the ECM enters closed loop operation, if it does it is more than likely a sensor reading or acting flakey.
Old Apr 21, 2008 | 01:58 PM
kline454's Avatar
yeah there are no codes and its only when you drive the car for 30min or more close doesnt matter in its close loop or not.
Old Apr 22, 2008 | 11:45 AM
WS Sick's Avatar
Since it doesn't matter about close or open loop for the miss to be present it could be several things really, are all the sparkplugs in tight, it could be the ign module getting hot. Also are all your grounds on the motor good?
Old Apr 22, 2008 | 01:33 PM
kline454's Avatar
yes plugs are all tight and have been replaced 2 times now and the problems still there also all ground are clean and tight, i replaced the ICM and seem to be running ok for now.
Old Apr 22, 2008 | 01:44 PM
ulakovic22's Avatar
What do you mean "cutting out"? A slight stumble, shutting off completely, a hard miss. Since you installed a new ICM you might try the spacer mod and get it off the head so it doesn't heat soak.
Old Apr 22, 2008 | 03:44 PM
kline454's Avatar
hard miss and or small stumble.
Quickss96
Jan 29, 2016 05:56 PM
smoknta
Aug 27, 2015 05:07 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
malikot02SS
Aug 15, 2015 01:11 PM
alphaauto
Jul 26, 2015 04:40 PM
