Jegs oil pan
Old Apr 21, 2008 | 12:11 AM
Chevyguy358's Avatar
Jegs oil pan
Is anyone using this on a 383 lt1....if so what do u guys think of it. Any issues with clearance etc. http://www.jegs.com/i/JEGS/555/50223/10002/-1
Old Apr 23, 2008 | 10:09 AM
DAVE00's Avatar
Looks very similar to my Canton oil pan. Mine works fine but rests a bit on the front ontop of the powersteering. Might call Jegs and see what they recc for your app.
Old Apr 23, 2008 | 06:34 PM
well i just recieved it today and will be installing it soon...I will post the results
Old Apr 23, 2008 | 07:09 PM
TeamingTealZ28's Avatar
You gunna do it with the engine in the car?
If so......post some pics
Old Apr 23, 2008 | 07:30 PM
Yea I hope so anyway I have a cherry picker supporting the motor...i got the stock pan out this way but will have to see if i can get the new pan on...I will take pics
Old Apr 24, 2008 | 07:15 AM
DAVE00's Avatar
Hey FYI - I recently replaced my pan gasket with my motor in place and was able to completely pull the pan (canton 15-244t race pan) - see link below:
http://www.cantonracingproducts.com/...ace.html#15244
Just used a bottle jack on the balancer and pivoted the motor up and removed the motor mounts and pulled her out. Quite a PITA but it's do'able. Good luck with that.
Old Apr 25, 2008 | 01:06 AM
just an update...to anyone that might attempt this its fairly difficult..I have removed the motor mount bolts and the tranny crossmember and torque arm. I have a cherry picker supporting the motor and a floor jack under the rear of the trans. I have pushed the motor as far back to the back of the firewall and still dont have enough clearance between the kmember and the bottom of the pan. I am goin to have to drop the k member down a few inches to clear it. and then maybe it will fit. what a pain
Old Apr 25, 2008 | 01:12 PM
well the idiots at jegs sent me the wrong pickup tube...it physically will not fit in the pan with the pump, funny enough the fist thing that I saw when I opened the package was sheet suggesting complimentary components for the pan which listed a pickup tube which was not the one recieved. I even called when I recieved it and they reassured me it was the right one. as you can tell i'm pretty pissed. And yes the pan will fit but you have to drop the kmember in addition to the rest of the procedure.
Old Apr 25, 2008 | 02:34 PM
Dave1980's Avatar
Wow I was not aware that pan would fit to begin with. That sucks about the pickup tube.
Old May 30, 2008 | 08:15 AM
kgkern01's Avatar
Any update on this pan?
Old Aug 2, 2008 | 11:54 AM
kgkern01's Avatar
Still wondering about updates, going to 383 and wanted to know how header clearance and fit has held up?
Old Aug 2, 2008 | 02:40 PM
ABA383's Avatar
Im curious too...Im in the market for a new oil pan and this one seems like it would be nice...I dont want one with kick outs for header/starter clearance issues...and the price of this one seems pretty good...
--Alan
Old Aug 2, 2008 | 05:14 PM
Its a good pan it fits good i did have to bend the crank scaper to fit it properly in the right rear side of the pan and to allow the dipstick to fit in. i do now have a moderate oil leak but I haven't isolated the exact place that it is leaking. i would recommend this pan especially if the motor is out of the car. Make sure to get the correct reccomended pan gasket, hopefully a jeg's rep will tell you...they said nothing to me
Old Aug 8, 2008 | 07:27 PM
kgkern01's Avatar
Do you have any pics of it installed in the car? Does it fit well with long tubes?
Old Aug 8, 2008 | 10:12 PM
fits great with long tubes...you will prolly have to drop the k member during its install
