Waterpump seal for timing cover
Old Apr 19, 2008 | 02:46 PM
lt1loudmouth07
Guest
Posts: n/a
Can i buy these seprate ive been through 4 of them and buying the whole kit is starting to get exspensive lol everytime i do the socket method i break the seal and i lube it pretty good does anyone no the part number on these so i can just buy alot of them
Old Apr 19, 2008 | 04:00 PM
94formbird's Avatar
call gm and get the part number
i had to get 2
thay are about 5 bucks each
Old Apr 23, 2008 | 10:29 AM
DAVE00's Avatar
had the same problem, make sure you use the pen cap method as you need to get it over the waterpump input shaft without tearing it. Here is a good writeup link that will help:
http://www.impalaclub.com/naisso/for...TOPIC_ID=30984
Old Apr 23, 2008 | 03:46 PM
lt1loudmouth07
Guest
Posts: n/a
seals
Well the good news is i got my waterpump and opti seal on good but my crank seal is leaking and i even thought i had that on really good. any sugestions ?
Old Apr 23, 2008 | 04:02 PM
As long as you have no grooves on the hub that could cause it to leak, the seal must be put on straight and flat the whole way. If you don't do it this way, it can bend. If it gets bent, it will leak. It should also be installed fully into the cover.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
