new lifters help wanted
Old Apr 29, 2008 | 08:27 AM
onetransam4u2nv's Avatar
I have replaced my 95 lt1 with a 96 lt1 but the 96 has been sitting for a while it only had 20,000 miles on it. I switched the lt4 hot cam and roller rockers and car runs great but when i start it up it makes a tick till it warms up up then goes away so i believe that the lifter was compressed for such a long time that it takes a while for it to build up pressure but once shut off it does not hold. so my question is and i have done a search on it and have gotten mixed results WILL LS7 LIFTERS WORK WITH STOCK LENGTH PUSH RODS? So if anyone can help i would really like some info on this swap. thanks
Old Apr 29, 2008 | 10:26 AM
anyone?
no ones using ls7 lifters in lt1?
Old Apr 29, 2008 | 10:46 AM
Pezcore67's Avatar
I've had a similar problem when i did my lt4 hot cam swap. The sound never went away and i used brand spankin new lifters. Then i pinpointed where it was coming from and switch back to my stockers in the spot and it still did it. The car all and all runs great and i know i have my rockers set right so i just leave alone and drive it. I havent had any problems thus far and its been about 10,000 miles.
Old Apr 29, 2008 | 10:54 AM
The Engineer's Avatar
How much pre-load adjustment are you adding after 0-Lash? Now that the engine has been run some, you could re-do the lifter adjustment and see if that helps the problem (simple and cheep).
WD
Old Apr 29, 2008 | 11:04 AM
preload
i have re set the preload thinking that might be the problem still does it but only when its cold goes away when warm. and only on passenger side.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Noer
Feb 28, 2015 11:29 AM
jayblev95
Dec 1, 2014 06:55 AM
siguy
Nov 27, 2014 10:07 AM
