P1sc LT1 vs. GM847 LT1
local kid is starting to run his mouth bad, he has a 94 formula with a 355 and a P1sc,auto, 2400 stall stock heads, GM hotcam, and a few other basic boltons.
i have my 97 SS vert with a 355 10.8:1, 6 speed with the GM847 cam, i also have slight head work with a 5 angle valve job and stainless valves, i also have 4.10 gears and the rest of your basic boltons and other things to support the 355 and cam. my car last time at the track went 13.322@91mph with me letting off (no cage and verts can only go 13.5) i never realy got on it at the track with an astonishing 2.4 60 foot
i also have a 150 shot on the car.
i should add this 355 came out of my 95 Z28 and i went 12.7 NA with the cc503 cam and an automatic.
think its even worth racing?
i also have a 150 shot on the car.i should add this 355 came out of my 95 Z28 and i went 12.7 NA with the cc503 cam and an automatic.
If you can hook it up with some Drag Radials it shouldn't be much of a race. No drag radials and if he knows how to drive at all, you may be watching him take off faster and faster while your still trying to get traction.
without some spray he might get you...don't most supercharged cammed lt1's put down mid-400's to the rear? correct me if im wrong...im assuming you probably have around 400 or so to the wheels...throw a 100shot on and embarass him
hes running 8psi, and the kid is 15, but his dad is like 50 something and runs his mouth too, so id like to put him down and make some cash, and by the sounds of it ill bump the spray up to a 200 shot
motor is built for 400 and i put 350 through it inside my Z
if he gets any more cocky ill slap my 28x11.5 ET streets on and my skinnies up front. oh and be assured i will record it!
