Need some help! Car died.... Ideas????
Old Apr 26, 2008 | 03:57 PM
94SLUG's Avatar
Lightbulb Need some help! Car died.... Ideas???? Update! More help!
I was driving for the first time of the year and it began to hickup a tad, and then it went from 8 cyl, to, 6yl, to 4cyl, and now it will not run at all. Cranks over fine.. If I hold the gas to WOT it wants to start almost like the timing is way off. Before it died I had a low res pulse code, so I figured the opti totally died and replaced full unit with delco. No worky! Then for some dumb reason I just bought a new ICM NO WORKY. I had a spare coil tried it still no worky. New wires also... Spark seems great. So my fuel pressure gauge reads 46psi before start... Pump is working.... What the hell else am I forgetting...
Bill
Old Apr 26, 2008 | 04:01 PM
mrmint69's Avatar
Hows the connection for the opti look? Did you check for spark?
Old Apr 27, 2008 | 12:49 PM
94SLUG's Avatar
Connection is good so is the spark.
Bump Ideas
Old Apr 27, 2008 | 01:04 PM
Pullngz's Avatar
You have spark at the plugs? Plugs are good? Are your injectors working? New wires before or after you started having problems?
Old Apr 28, 2008 | 11:44 AM
94SLUG's Avatar
OK so I got the car started under two conditions.. 1 I disconnected the MAF and 2 I had to hold it at WOT... I will try again with MAF connected... If it starts with the MAF connected and WOT where should I look? Is this the symptoms of leaky injectors?
97SSdude
Dec 31, 2014 07:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Alucard
Jul 29, 2002 10:30 PM
Absolute Z28
Jul 19, 2002 02:21 PM
