After leaving window open in a down pour, car wont start.
Old Apr 29, 2008 | 01:52 PM
TeamingTealZ28's Avatar
Weird Problem, Car wont turn over after rain storm??
Well its been raining like crazy here in NY.
Yesterday I went to get in the car and it wouldnt start. Like the alarm was armed, maybe
I pressed the UNLOCK button on the keypad and it started right up.
But today
I go and try to start it and it wont turn over, its got all electronics, lights come on, no problems. Just when I turn the key it wont start...clutch is to the floor and all. I dont know what happened
Its a 96 M6 Z28 with the factory alarm.
And it DID RAIN LIKE CRAZY...so maybe somthing got wet??
Old Apr 29, 2008 | 07:28 PM
mrmint69's Avatar
If the opti got water in it that could cause problems. Try it again after it has been sitting.
Old Apr 29, 2008 | 09:05 PM
But it wont crank. It wont do ****.
Another thing.
I left the window slightly open, so everything on the side got wet. Its like it wont crank over when u dont press in the clutch.
Old Apr 30, 2008 | 12:04 AM
mrmint69's Avatar
If the battery is charged and the starter is good then it should at least crank over. If the fuse box got wet and you started it maybe one of them blew. Just a shot in the dark but thats all i can think of right now.
Old Apr 30, 2008 | 03:06 AM
I bypassed the Clutch Position Switch with a wire to see if that was just shot......Nothing
I checked all of the in-cabin fuses....All good
I'll look again tomorrow at other fuses.
This sucks
Old Apr 30, 2008 | 09:46 AM
Well I left my window half down and it rained like crazy 2 days ago.
Now my car wont start.
1st time it did it. All I did was press UNLOCK on the keypad and then it started.
2nd time, It wont start at all.
Heres what I did.
I reprogrammed the keypad....nothing
I jumped the Clutch position sensor with a wire....noting
Pulled a bunch of fuses....nothing
unhooked battery......nothing
Anything else?
When I try to start it, the "Theft Deterrent Relay" in the glove box clicks...is that supposed to do it
96 Z28 M6
Factory Alarm
Old Apr 30, 2008 | 01:10 PM
Just bought a brand new Neutral Safety Switch...Clutch switch on manuals.
And still nothing!!
Old Apr 30, 2008 | 01:39 PM
Starting a duplicate thread in another forum usually doesn't help you, since no one in this thread will be familiar with the post made in the other thread, what has already been suggested, what your repsonses were, etc. That's why we generally discourage it.
Old Apr 30, 2008 | 03:37 PM
I know. Im very frustrated. Im sorry.
Its werid, dosent seem like the forum had many new posts or threads these past few days. so I thought it was just the section it was in.
Sorry about that.
Old Apr 30, 2008 | 05:19 PM
Not sure why you posted an LT1 no-start problem on "General F-Body Tech & Info".... would have made more sense to post it here. I'll merge your other post into this one here.
Old May 1, 2008 | 01:16 AM
Anyone.
I replaced the Neutral Safety switch and nothing and I replaced the Theft Deterrent Relay and STILL nothing.
I am going to replace the starter tomorrow.
Old May 1, 2008 | 07:16 AM
DAVE00's Avatar
Originally Posted by TeamingTealZ28
Anyone.
Are you getting the security light on your dash when you try and crank it as it could be your VATS? Just a guess!!
Check out this thread:
https://www.camaroz28.com/forums/sho...highlight=vats
Also, dumb question, but do you have a kill switch with the alarm as I have a black bypass button under the dash on my 95 T/A that was installed with the factory alarm and it bypasses the kill switch if the alarm is going off and I have the key in the ignition allowing me to start her. Just a thought.
Old May 1, 2008 | 08:08 PM
mrmint69's Avatar
On my sons 98 you can put straight power to the wire that runs along the passenger side of the engine bay. I think there is a spot where you can uncap or get to the wire. It won't stay running but at least it will help eliminate some parts. I used a copper wire i had laying around and put one end on the battery and the other to the wire. I think it is the straight power to the starter i believe but the injectors won't work so it will die right away.
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
The Seer
Nov 20, 2014 06:32 AM
Dave19yz28
Jan 26, 2003 01:45 PM
