Thought I would share my optispark problem
I just bought a 94 LT1 that started misfiring around 3000 RPMS, and would get worse as the engine warmed up. The car had an MSD opti cap and rotor that is only a year old, but was getting a high pulse rate and low pulse rate code. So I decided to check it anyways. Turns out the screws for the rotor fell out and were just flopping around inside the cap. I got a new opti on the way anyways, and hopefully we will be in business.
Also, anyone know the exact thread size of the rotor screws???
I would sure like to replace those Torx heads with some simple hex head or maybe even phillips head screws.
Why is GM sooooooo ...... in love with Torx head screws.
I don't know, probably to frustrate the "average joe" who doesn't have a set in their toolbox. The better part is where they use the inverted torx fasteners, even alot of mechanics don't have those types of sockets in their toolbox.
You are correct the Optispark cap requires an "inverted" Torx bit, but the rotor screws are just a very small "regular" Torx screw. If you say you used the "E4" (inverted Torx) socket on the cap .... maybe the rotor screws just take a regular T-4 size Torx bit???
Anyone know for sure?
Haha, people at ACE hardware looked at me like I was crazy when I described it. I found it as AZ.
IMO the reason guy have good lucjk with new OEM optis is because the come assembled.
I have no problem with my MSD cap and rotor kit then again I put it together right even using the admittedly small screws supplied, that was 15K miles ago or so.
Both the GM and MSD Optis have their strong and weak points, however, for performance applications I still believe the MSD Opti is the best option.
WD
