Did the LT4 have lash caps on the valve stems?
Old Apr 22, 2008 | 09:14 PM
2QUIK6's Avatar
Just want to make certain that the LT4 did not have lash caps on the valves from the factory and removing the lash caps won't have any negative effects on the stock valves.
I know there are some valves made of soft metal where lash caps are required, and they can give a little added protection if something wears and gets the geometery screwed up, but I need to remove them in order to use the +.050 locks to give me enough spring install height.
Old Apr 22, 2008 | 09:20 PM
Stl94LT1's Avatar
There were no valve lash caps on the LT4's.
LeftoverChinese
Jan 14, 2024 03:03 PM
KamikaZ28
May 28, 2015 12:45 AM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
TA Jack
Sep 3, 2002 07:52 PM
