!egr question..
Old Apr 22, 2008 | 06:18 PM
EsCrasston's Avatar
!egr question..
I was told to put a resistor on the plug that goes into the egr solenoid.. how do I go about doing this and picking the right resistor?
thanks!
Old Apr 23, 2008 | 04:41 AM
red1984's Avatar
Why r u removing the EGR? Unless something is wrong with it you should just leave it on or you could have it tuned out. www.pcmforless.com can tune it out if you want to.
You might want to add a signature so that we know what kind of car you have and what mods have been done.
Old Apr 23, 2008 | 09:55 AM
EsCrasston's Avatar
I had the famous LT1 intake manifold leak so I just deleted it when I had the intake off.
p.s. is the sig better now? lol
and you didn't answer the question that I asked.. I know I can have it tuned out.
Old Apr 23, 2008 | 11:04 AM
ChevalierSS's Avatar
You have and OBD I car, just unplug it and go
Old Apr 23, 2008 | 11:15 AM
Incorrect... if you unplug the EGR vacuum solenoid in OBD-I you get DTC 27 for a faulty electrical circuit. To determine the correct resistor value, measure the ohms across the pins of the existing solenoid. Match that. Push the wire ends of the resistor into the harness connector so they make contact with the two pins in the connector, and tape it up.
His suggestion that you add a signature was a valid one.... not sure why you reacted the way you did. Its a lot easier to help you when you have that information available.
Old Apr 23, 2008 | 08:28 PM
EsCrasston's Avatar
Thanks for the help.
I know it was a valid suggestion, and I wasn't trying to be ignorant at all?
I apologize if it seemed that way.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
