abs inop
Old Apr 30, 2008 | 08:24 PM
Maverick_997's Avatar
abs inop
the light is always on when i turn the car on. what would make this light stay on like this.
Old Apr 30, 2008 | 08:29 PM
wrd1972's Avatar
Check the third break light. If a bulb is burned out it will cause the ABS light to come on.
Old Apr 30, 2008 | 08:33 PM
i checked all break lights and found out that one on the right side wasnt working, i replaced it and still the ABS INOP light is on. any others reasons it would be on?? could the fuse in the engine bay be bad??
Old Apr 30, 2008 | 08:38 PM
n2ceptor's Avatar
1. Check fluid level....
2. There is a negative ground on the passenger side inner fender..( Close to the red positive box) Mine came loose when working on that side.....
3. Check wheel/differential sensors connections...
4. Maybe someone else will chime in??????
Old Apr 30, 2008 | 08:59 PM
camzaro28's Avatar
Mine came on due to the 3rd option from n2ceptor.
Old Apr 30, 2008 | 09:20 PM
i havent dealt with any censors in that area, do you have any pics of what the plug looks like??
Old Apr 30, 2008 | 09:35 PM
camzaro28's Avatar
I cant find any pictures on shbox site, but if under the front of the car, it is very easy to spot.
I believe it is the only plug harness near the inside of the wheel.
Old May 1, 2008 | 01:03 AM
alright ill look into it and let you know what i can find thanks for the help
Old May 1, 2008 | 04:56 AM
bombebomb's Avatar
Mine blinks on every now and again, ill keep tabs on this thread, Iv just been to lazy to check whats causeing it, since it is rarely on.
Old May 1, 2008 | 06:04 AM
2000GTP's Avatar
http://shbox.com/1/front_hub.jpg
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
realistyc
Jul 28, 2015 07:32 PM
