What is the best Header Gasket!!
Old Apr 29, 2008 | 08:17 AM
94YellowTAGT's Avatar
I am going to replace mine due to a little tick from the passenger side header.
My headers in the sig.
Thanks,
Old Apr 29, 2008 | 08:27 AM
Joe87MonteSS's Avatar
This may sound crazy, but I use stock foil type manifold gaskets with my headers. Never any leaks. I also use Stage 8 locking header bolts.
Old Apr 29, 2008 | 08:31 AM
maverickmk's Avatar
same here, but sometimes I'll double them up on cheap headers if the flange is a little wavy
Old Apr 29, 2008 | 08:54 AM
awdfun's Avatar
Earls Pressure master
http://www.holley.com/29DA3BERL.asp
Old Apr 29, 2008 | 09:38 AM
Originally Posted by awdfun
Anyone else had experience with these?
Old Apr 29, 2008 | 09:52 AM
526 SS 96's Avatar
+1
I won't use any other.
Old Apr 29, 2008 | 09:55 AM
cause4panic's Avatar
+1 only thing that comes close is perceys dead soft.
Old Apr 29, 2008 | 10:05 AM
Just ordered them.
Thanks for the advice guys!
Old Apr 29, 2008 | 12:25 PM
96' Formula WS6's Avatar
yup i used those earls and stage 8 bolts and never had to retighten, every time i checked them they were snug. will def go that route again if i had to.
Old Apr 29, 2008 | 12:27 PM
Pezcore67's Avatar
I use mr. gasket with acousti seal on both sides of the gasket. Drivers side has been leak free for sometime now. Passenger side needs to be done.
Old Apr 29, 2008 | 01:04 PM
NVetro's Avatar
This is what I did on my new 383 motor...no leaks at all...get the normal felpro header gaskets and a set of split lock header bolts (breslin is no longer around but there are a few companies who still make them, one in australia i think, by far the BEST header bolts made)....
Soak the header gasket in warm water for 10 minutes before installing....put them on (while still wet) with the split lock bolts and then tighten the allen on the head to lock them in place. I did this last year and no leaks what so ever.
Old Apr 29, 2008 | 01:05 PM
caldercay's Avatar
Fel-Pro 1470
Old Apr 29, 2008 | 02:41 PM
cotton42090's Avatar
i'm guessing it makes it so the gasket forms to the surfaces better? sounds like a good idea to me.
Old Apr 29, 2008 | 03:44 PM
ssbowtie1's Avatar
This is what I did thanks to NVetro's idea. Seems to seal just fine. Haven't had to re-tighten the breslins, not even once!
I am, however, still trying to figure out how to stop that stupid slip fit primary from leaking
Old Apr 29, 2008 | 03:48 PM
ssclone's Avatar
stock exhaust manifold gaskets, and never had a problem, plus they are only 5 bucks a set.
aaron
