alternator brackets
Old Apr 26, 2008 | 07:55 PM
ARZ28's Avatar
alternator brackets
1994 z28 lt1 i just put my heads back on and i cant remember how the small bracket for the alternator mounts.does it go to the first header bolt then to the alternator.do i use threaded bolt and then the bracket and then a nut?thanks i just dont want to screw it up.
Old Apr 26, 2008 | 07:57 PM
mdacton's Avatar
the little bracket made out of metal rods?
2 bolts go to the back of the alt. the end with the hole goes to a stud on the intake bolt. I think the 2nd or 3rd one back
Old Apr 26, 2008 | 08:08 PM
ARZ28's Avatar
yes but then there is a small single bracket that would mount to the other bolt on the alternator.i have the bracket that you are talking about on and that lined up good but i dont know where the small bracket goes
Old Apr 26, 2008 | 09:10 PM
mdacton's Avatar
have a picture of it?
Is it the little L shaped one off the AC compressor?
Old Apr 26, 2008 | 11:10 PM
ARZ28's Avatar
yes it is kinds L shaped and has to flat ends.it is about five or six inches long. no i dont have a picture.
Old Apr 26, 2008 | 11:31 PM
You use a bolt with a stud protruding on the first exhaust manifold bolt hole. Then attach the bracket to the stud, holding it on with a nut. The bracket bolts to the back of the alternator with a bolt.
Here are a couple of pics that might help: (ignore the yellow circles-these are pictures that go with other instructions)
http://shbox.com/ci/ci417.jpg
http://shbox.com/ci/ci178.jpg
Old Apr 27, 2008 | 09:08 AM
ARZ28's Avatar
thank you thats how i thought it went on pics very helpful.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
War Engine
Sep 18, 2015 07:28 PM
