AFR (GTP) Lt4 heads ????
Old Apr 29, 2008 | 06:46 PM
Dannysz28's Avatar
I have a set of AFR 195cc LT4 heads that were ported by GTP (stage 2)to 210cc. I was wondering if anyone could recommend an intake and exhaust gasket for these. I dont think GTP is in business anymore and afr wont recommend a gasket since they were ported by GTP.
Old Apr 29, 2008 | 08:03 PM
CANTONRACER's Avatar
I run LT4 intake gaskets that I have to open up for my runners.
On the exhaust side I use Mr. Gasket #5903, which is a good fit.
Old Apr 29, 2008 | 08:25 PM
The Engineer's Avatar
Just wondering what size intake valves you have in your 195s? I have the old 195s w/ 2.02 intakes, so I'm planning to have Lloyd Elliot work them over off-season and go to 2.05s.
WD
Old Apr 30, 2008 | 06:53 PM
Dannysz28's Avatar
I have not measured them but the guy i got them from said they were 2.08
Old Apr 30, 2008 | 07:47 PM
From what I've heard, with the 2.05 valve upgrades you can reuse the original valve seats in the AFR 195s. However, with the 2.08s the seats will need to be replaced. Again, that is what I've heard, not for sure.
Also, did they retain the D-port design on the exhaust ports with your port work? For some reason, I’ve always liked the D-port exhausts and have Kooks headers with the D-port flange.
WD
Old Apr 30, 2008 | 07:50 PM
Dannysz28's Avatar
They are more of a square shape
Old Apr 30, 2008 | 08:06 PM
I think the AFR 210s use a square exhaust port, rather than the Ds. Can you post some photos of your reworked 195s?
WD
LeftoverChinese
Jan 14, 2024 03:03 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
95chwagon
May 27, 2015 09:53 AM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
