oil
Old Mar 12, 2003 | 04:57 PM
wannabe96z's Avatar
oil
I just got a 96 z, the oil is due a change and it's black, is this ok, i can smell what seems like a little oil when i drive the car a while, is this normal, also i just checked the oil today and its on the add line, do you think i have a problem? thanks for the help
btw, does my car use 10w-30?
Old Mar 12, 2003 | 05:43 PM
kick Z tail out's Avatar
Exclamation
Oil always gets real black and thick when it's due. Change it as soon as you can though, don't cruise around for the next two weeks.
I used to change my oil every 2500 for the hell of it. I was **** about keeping new fluid in it.
The factory called for 5W-30, but 10W-30 is just fine to use. What's your mileage anyway?
Sounds like it is burning oil.
Old Mar 12, 2003 | 06:03 PM
96cam4ro's Avatar
5w30 is what is called for, but 10w30 is fine. If you see bluish smoke from the tailpipes, you're burning oil. If not, then you're leaking oil onto the exhaust where it's getting burnt and causing the smell.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
