backspacing with weld wheels
Old Mar 13, 2003 | 11:54 AM
rdy2run's Avatar
I was just wondering what backspacing I would need with weld wheels on the rear.
Old Mar 13, 2003 | 11:58 AM
For 15x8's use 5.5"BS
For 15x10's use 7.5" BS.
You will have to grind the fins off the calipers if you use the Pro-Stars or Drag-Lites.
EDIT: This is a 15x10 7.5"BS Pro-Star, with a 28" QTP:
15x10 7.5" BS Pro Star
The 15.8 5.5" BS will put the outer edge of the tire/wheel in the same location.
sweet94Z's Avatar
I run 7.5" on a 10" wheel. It looks good and tucks up under nicely.
PCLZ28
Wheels and Tires
May 8, 2015 08:39 PM
Ken Cemo
Mar 31, 2015 08:50 AM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
Speeds8erM-1
Aug 13, 2002 10:24 PM
