O2 sensors
Old Mar 14, 2003 | 12:51 AM
Deadcarny's Avatar
O2 sensors
is it okay to splice an extension onto an O2 sensor? i had a y pipe made the other day and they welded the bung too far from the plug for the O2, so they spliced and extension from the wires of another O2 sensor. i have a very small leak at the flange where the header and Ypipe meet and my left bank is VERY LEAN. i am wondering if it is all from the leak, or maybe a combination of a NOW-bad O2 sensor and the leak.
anybody know where to buy O2 extensions for the rectangle plug O2 sensors?
Old Mar 14, 2003 | 02:34 AM
Rasta's Avatar
http://www.thunderracing.com/
Old Mar 14, 2003 | 02:40 AM
Deadcarny's Avatar
thanks for the link on the extension!
anybody know about the splicing question?
Old Mar 14, 2003 | 08:13 AM
Splicing is ok if done correctly. On an O2, I would personally not rely on anything but a soldered connection. The small voltages that the sensor uses could be very susceptible to a poor connection.
That said, if you have a leak, you need to fix that and re-evaluate before chasing anything else.
Old Mar 14, 2003 | 08:38 AM
Mikael's Avatar
Sorry to tell you, but you need to buy a new sensor. You can't cut the wires of the sensor, only the harness wires that are on the car.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
