brake light stuck on after a hard lockup
Old Mar 13, 2003 | 10:42 AM
ericz28w's Avatar
Angry brake light stuck on after a hard lockup
i was crusin one day and then this retard pulled out in frount of me and i had to slam on the brakes and hit the ditch, if i pump the brakes the light goes off, but i have no idea whats goin wrong with my brakes. please help!!!!!!
Old Mar 13, 2003 | 11:27 AM
CODY BEHNKE's Avatar
Is it the brake lights or the brake warning light that stays on?
If it is the brake lights the push switch is jammed, if the interior warning light is on it is low on fluid.
Old Mar 13, 2003 | 12:49 PM
UkraineTrain350's Avatar
there's a spring loaded switch on your brake pedal, take a look at it
Old Mar 17, 2003 | 10:19 AM
ericz28w's Avatar
i checked the fluid and its ok, P.S its the brake light in the dash.
thanx!
Old Mar 17, 2003 | 10:43 AM
Have your brakes checked... the "brake" light comes on for at least two purposes... one is to show you the emergency brake is on. The other is to tell you there is an unexplained differential pressure between the front and rear braking circuits. If you look at the big "block" on the side of the ABS motor, where the lines from the master cylinder connect, there is an electric connection. This is for the switch that senses differential pressure. You may have a leak in either ther front or rear circuits, air in one of them, or the fluid is so low, only one of the circuits is getting fluid. Or maybe the pressure differential switch is faulty.
WildRidez
Feb 23, 2015 07:24 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
