will v6 guages work on a v8?
Old Mar 13, 2003 | 04:11 PM
ponykiller z28's Avatar
Question will v6 guages work on a v8?
i am in the process of swapping an lt1 in replace of my 3.8......
are the z28 guages absolutely necessary? or can i just leave my 3.8 guages in.? also, how hard would it be to switch guages?
Old Mar 13, 2003 | 09:35 PM
nobody knows?
Old Mar 13, 2003 | 09:48 PM
TheV6Bird's Avatar
Yes, you are going to need the gauges.
The reason you need the gauges is because you need to use the LT1 PCM. I am sure the gauges will work....they will just read wrong.
Not only will you speedo be off, but what about oil pressure? That might be different for LT1 than from the 3.8s.
I don't think gauge swapping is that hard; ask around in V6 Tech, a few guys have swapped their V6s for V8s
Old Mar 14, 2003 | 11:20 AM
ok thanks
Old Mar 14, 2003 | 11:59 AM
Hold on... the only problem will be the tach.
The oil pressure, coolant temp, fuel level and voltmeter are connected directly to the source sensor, not through the PCM. The speedo will interface fine... the PCM takes care of things.
Only the tach will mismatch... its expecting 6 pulses per engine rev, and its going to see 8 pulses..... will read 33% too high.
I would think that getting a V8 155mph cluster would be worth it though, just to get the 155mph speedo...... .
Old Mar 14, 2003 | 04:26 PM
TheV6Bird's Avatar
I didn't know about that, I got my info from TACreations.com
Old Mar 14, 2003 | 05:07 PM
Eddie95Z28's Avatar
From the link you gave:
Gauges : Required for the tachometer to read accurately. The tachometer will be approx 20% off without changing to V8 gauges. All the other gauges will function.
EDIT:
whoops, I misread your post. I thought you said "I DON'T know about that." as if you were disagreeing. My mistake.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Lions3
Aug 6, 2002 05:33 PM
