Is It Ok To Drive My A4 Home After 3.42 Gear Change Without Programmnig
Old Mar 13, 2003 | 01:26 PM
z28ponyeater's Avatar
im going from 2.73 to 3.42. im going to get the pcm programmed, but can i drive it home from the shop without programming? i was thinking maybe i could manually shift it and keep it in 3 and go slow. is this not a good idea?? thanks in advance!
Old Mar 13, 2003 | 01:31 PM
Draco's Avatar
Re: Is It Ok To Drive My A4 Home After 3.42 Gear Change Without Programmnig
You should be fine. The RPM is measured before the rear end gears so your shift points should not be affected. Your speed will appear much higher though on your speedo (approx 25% higher) then what you will be really travelling at.
Old Mar 13, 2003 | 01:41 PM
dlx3200's Avatar
Thumbs up
You should be fine.I went from 273's to 410's. I had to program my pcm for speed to be right, but didn't touch the shift points.
Old Mar 13, 2003 | 01:50 PM
James3219's Avatar
I drove about 20 miles back home after I went from 273's to 323's. I hurt nothing by doing this, but my speedo was reading like 50 when I was going maybe 25-30.
Old Mar 13, 2003 | 02:08 PM
Smoke T/A's Avatar
Hey I can reprogram your car after it gets out of the shop . LMK I have tuner cat and can pretty much do what you want done? LMK
Joe
Old Mar 13, 2003 | 05:20 PM
ok i just wanted to make sure because ive heard that the shift points are set on mph and when you get to a certain mph the pcm changes the gear. thanks for the replys guys!!
Old Mar 13, 2003 | 08:04 PM
Mtrhds94Z's Avatar
I also agree that the shift points are governed by MPH, throttle position, etc.. not RPM..
Old Mar 13, 2003 | 08:47 PM
James3219's Avatar
As long as he does not go WOT on the way home or until he gets it reprogrammed it should not matter.
PCLZ28
Dec 24, 2015 05:19 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
x7x7
Aug 15, 2002 06:49 PM
